Discuss issuing eicr in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Not personally a registered member to a scheme as I am employed to a firm that is.
i understand you obviously have to be to signed off work or issue a eic.
but what about a eicr?
I have my 2395- is this enough to issue and sign a eicr?
yes. without a shadow of a doubt. there is no requirement for you to have been suckered in by a scam to do EICRs. just that some bodies like councils and insurance companies insist on niceic because they don't know ant better.
as above. you don't need to be in a scam to issue a EIC. totaly dufferent from notification, if required, on domestic work.
As I thought you do not have to be part of a scam as you guys love to call it ie niceic to issue a eicr.
but to issue a eic I thought you had to be a registered member or pay for building control to sign it off.
and I know what notifable work is thanks!- that wasn't the question
You don't need to be registered with anyone to issue an EICR.... equally you don't need to be registered with anyone to issue an EIC.
Notification of work to building control is a separate matter.. as already said in this thread.
Only if the work is notifiable under part P. Some domestic work will be like installing a new circuit or altering a circuit in a special location.
Part P only applies to domestic work, not commercial/industrial etc.
Eic would be issued for a new circuit or fuse board change etc....both notifable- so both need a register member
Registration with a scheme makes notification easier, but does not affect the issuing of any certification required by BS7671 to a customer.
Seem to be drifting a little.
You SHOULD issue a EIC if you install a new circuit. which is notifable- so you need to be registered or notify b.c
surely any work requiring a EIC will be notifable
Only in a domestic situation but even then, I'm not sure that all work needing an EIC is notifiable. A download of approved document P will help you out mate.
Do not go down that route.
Keep BS7617 and the building regulations separate in your mind.
The application and ramifications are different and should be considered as different.
There may well be situations where an EIC may be issued without requiring notification to building control, say on small changes to multiple circuits.
Yes, but in post 5 you said that you need to be a scheme member to issue an EIC, which you don't. You can notify work through a scheme though.
Back to your original question.... if you are going to be carrying out EICRs outside your normal work, then professional indemnity insurance is a wise move.
What will this cover?
Reply to issuing eicr in the UK Electrical Forum area at ElectriciansForums.net
Hello there. I've been looking around here and found some conflicting information. I have a question if I may ask. I had an electrician come over...
4K
Hi everyone, I recently moved out of my rented property, and as expected, my landlord is attempting to withhold a significant portion of my...
Good morning, We have a two-bedroom flat that my wife and I rent out to supplement our income. Following the recent EICR, several issues...
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
