Discuss Joining 10mm to 2.5mm T+E in the Australia area at ElectriciansForums.net
din rail terminal blocks in your adaptable box. hope you;re fusing down at the feed of the 10mm to 16A or 20A.
Or alternatively,a fused spur where the reduction takes place
Reckon that may be a bit of a squeeze..... ?
You want one of the Newlec adapatable boxes that come with the rail mlountable connectors. The connection itself is 2 seperate terminals meaning you could join any size cable to any other size as each one has a seperate terminal.
Like that, all ready made simples...... do you know if they come in various sizes ?
Reply to Joining 10mm to 2.5mm T+E in the Australia area at ElectriciansForums.net
