Discuss Joining cables. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello everyone I am new to this site and always a bit worried about coming on forums for advice because I've heard people say about people being sarcastic, nasty or putting you down because you have asked a silly question, I'm an audio visual engineer of a small company and they put me on one of those month long courses a few years ago and past all the exams but I never class myself as an electrician but also I have never had anyone to turn to for advice or help so I just refer to the internet and wiring regs for help but this time I have bit the bullet and joined this site. Here is my question I did some work in a school last year and I joined a number of cables together the old black and red and extended them with brown and blue, I crimped all my joins and tidyly put them back in to the metal conduit, the conduit is earthed. My boss just spoke to me and said they had the system inspected and it was said that the inspector was surprised that the joints were in metal conduit and not pulled out and joined in a plastic box but upon looking at the regs it states that "where a connection is made in an enclosure the enclosure shall provide adequate mechanical protection and protection against relevant external influences". That's on page 107 ref 526.7 I may be reading this wrong and misunderstood it can anyone clarify this is it wrong to do joins in metal conduit that is earthed or should I have done all the joins in a plastic box.
thanks for listening.
Mel
Mel welcome to the forum and despite what you've heard we don't bite.
The only thing we ask of new members is that they are as transparent and clear as possible and provide all relevant info so the members can assist you correctly.
Joints can be contained in metal trunking or conduit boxes with no problem. It would be better to fit a metal box to the trunking to house the joint, especially if there are more than one or two cables to be joined.
In my opinion the idea of fitting a plastic box to steel trunking to make connections would be bad practice. If a box is needed it should be a steel one to afford the same protection as the trunking does.
You're using the wrong regs book ...
Mel
Home : Oxford English Dictionary
Hi melly the regulations has seen a few ammendments since the publication of that book we had a green one after the red and we have now just introduced the Yellow book with the third ammendment.
The cable joints would be better taken into an enclosure to be fair. You need to consider the environment it is in, what the likely hazards are and then you can decide if plastic or metal will be suitable.
Reply to Joining cables. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hello All, New to the Solar world. A question that is most likely easy, if you can tell me where I can find this in the regs or ACOP please let...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
