Discuss Junction Box For New Outside Lights in the UK Electrical Forum area at ElectriciansForums.net
I’ve installed several outside lights I need to make another cable join in a junction box and then fix it to the wall outside the problem I have is i’ve run out of the junction boxes I was using I do have a standard one the plan is to use the standard junction box I have in stock and insulate the inside of the box with sugar mixed with super glue to give it water resistance does anybody know if this will work?
Buy a box lazy. ----ing about with a potion
Reply to Junction Box For New Outside Lights in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
Hi, I do basic electrical DIY like changing light fittings and have got a light to put up that only has a fly earth and no flex earth (see pic)...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
