Discuss Lamps blowing!! in the UK Electrical Forum area at ElectriciansForums.net
Simply fit LED lamps and seem what happens, buying from the likes of screwfix is your first problem. Halogens create such heat which can oftener turn cause condensation. 'Cheap lamps' often don't refer to the purchase price, but the quality.
With a IR of 0.08 after only 9months, I'd be seriously worried about you installation methods and work practices,
I did mention trying LEDs Westie. And to need fair to HHD he did put the low IR down to crappy IP boxes. Can't really blame the installer for poor manufacturing processes.
Fit junk and expect to get burnt.
I can buy a LAP consumer unit fully loaded for £35 or so. Apparently meets AMD 3. It's gonna be great!
Agree that Lap is crap. Or then again do I?? I have never used any Lap gear so cannot really comment on them. Don't plan to purchase any soon though.
123, the OP did say the IP boxes got reasonable reviews did he not? So why should he be expecting to get burnt??
Well thought out VX, good on you.
Thought I'd try a fairly well reviewed IP box and it leaked. From that you have deduced all my installation practices are cause for serious concern (or as you have written 'you' concern). Your post seems most intelligent, with good spelling and backed up with good hard evidence.
Well done again VX, even more so with your almost 4 years on this site and having gained the thanks of 2 whole people, you truely are a helpful chap. Keep up the productive posts :smile5:
I apologise for my spelling, you, was meant to be 'my'.... I don't apologise for my opinion.
I like to think I'd have recognised I was fitting crap and not actually done so.
I'm not also the one questioning whether a low IR result would be causing lamps to blow or the one not checking landholders for damage or poor connection.
As others have said, fit Leds, correct the faults and learn not to fit ****e... With such a low IR when you tested, it may also be worth checking any RCD present for correct operation
Someone else and Tony have mentioned switching, two worst things you can do to an electrical piece of equipment, switch it on, switch it off.
If they're on off on off all day and night they won't last long....[/QUOTE]
Thats a really good point Sparty!! They are on a sensor in the countryside with foxes etc passing by all through the night. I bet they are going on/off all the time.
Plus, they are not blowing quite so often at the moment which could partly be down to the shorter darker hours so less switching. One blowing (out of 11) every 3 weeks, is the same as the same one blowing every 33 weeks, still not great but if it is switched on/off every 10 minutes (perhaps by a moving branch) then they will not last long. I think I will ask them to have a look at the security cameras and get an idea of how often they are switching through the night.
Cheers Spartykus! :smile5:
Are them for holding mines........they blow pretty well, too :army:
Reply to Lamps blowing!! in the UK Electrical Forum area at ElectriciansForums.net
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
Morning All Got little bit situation going on, causing multiple visits (luckily only 2 mins drive from where we are.) Client not 100% happy with...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Hi there I am getting someone in to change an outdoor switch and outdoor wall light (like for like). The old switch and light was covered by a...
