V
VicenteMMOS
Hello, everyone!
I'm brand new to this forum. I have a question regarding my laptop. Its input power is 240W @ 19.5 V, and about 12.3 A. Its power supply naturally outputs this amount (nominally), and draws from the socket 100-240V @ 3.5 A (50 - 60 Hz).
When I was working back in Italy (220 V, 60 Hz), everything works fine. But now that I'm in Brazil for vacation (110 V, 60 Hz), when I plug the power supply to the wall and turn the computer on, the power supply will just turn off after a while of use, as though it wasn't being able to draw enough power from the wall socket. Would you please help me troubleshoot this problem? Am I missing something obvious here?
Thank you so much.
It sounds like it should work ok though according to the spec.
How can he get 19.5 volts from both 240v and 110v? surely if the transformer in his power supply is set at one ratio to convert power down he'll get 19.5v from 240v and much less than 19.5v from 110v unless I'm missing something?
No. It will be a switch mode power supply that automatically adjusts. Most SMPSUs do this.
I wondered about frequency, but you say both are 60Hz.
Could you post a photo of the power supply? The side with all the writing on it.
I agree, sounds like a faulty SMPSU. Could be something simple like one of the caps dried out. Learning how to repair SMPSUs is something I'm playing around with at the moment. Got a 'Megger' SMPSU apart in front of me right now (6280-333 from a DLRO10 ductor). Megger want £90 + VAT for a replacement. It's giving 12v out but as soon as connect a load it drops to zero. At the moment it's charging well of a cheap 'no name' ebay SMPSU but would be nice to fix the original.
Anyway, back to the original poster, I would suggest looking at a replacement PSU.
Can be a nightmare. Sometimes something very minor, sometimes takes half the components out. And if you do happen to miss something then expect it to destroy itself again when you power it up!
Most are pretty easy going on frequency. Got 3 in front of me, Megger is 47-63Hz, Dell 50 - 60Hz, Lenovo 50-60 Hz.
I always make sure I buy a small bag of 'magic smoke' whenever I buy parts, just in case 🤣
have you tried it in a different socket (outlet)??
if that doesn't help, as above, a new power supply would be a good place to start.
