Discuss Leaving bulbs out of light fittings in the DIY Electrical Advice area at ElectriciansForums.net
u0362565
Hi all,
i've heard that if you have say a four bulb light fitting and you leave one or multiple bulbs out this can cause the bulbs that are there to fail early because they draw more current. Is there any truth in this? Don't they draw a constant current no matter how many bulbs there are? I'm using LED bulbs but can't see that the bulb type matters.
with standard lamps (incandescent, cfl, etc) each lamp will take the current it is designed for.
things may get more complicated with LEDs and constant current led drivers...
post some details what setup you have
Ok what would you like to know? It's a ceiling fitting which takes 4 gu10 type bulbs, it did have 4 halogen 35w spot lights and I've replaced with 5w LED spots. The LED bulbs are from ikea.
thanks
Hi all,
With all them bulbs you should have a nice floral decoration when they all bloom.
thanks
if they are mains gu10 then no problem
Reply to Leaving bulbs out of light fittings in the DIY Electrical Advice area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hey everyone, here's my imaginary problem, let's say I have 2 light bulbs, both of them take energy from the same source, however, 1 of them has a...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
