Discuss Led strip lights in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Fitting led strip lights in plant room,with diffuser,fitted base had probs fitting guts to base,so switched light on,& tried to push fitting on to base,stupid me,had my hands on led lights & got a shock.These leds give quite a belt,surely this could be dangerous for anyone,beware,is this really allowed.
The voltage at any LED block should be no more than 50V at max so technically safe.
I think I have seen 37V specified in a lot of cases, obviously if you have LED strip supplied from a driver then the voltage should be no more than the driver rating.
Thanks,will check with the guys on site what ratings they are,felt more than 50 v
Reply to Led strip lights in the UK Electrical Forum area at ElectriciansForums.net
Had to remove a led strip from a bathroom today because it’s getting tiled, now the led strip that was there was low voltage but didn’t have...
Hi Guys I've fitted 12m of LED strip light 9.6watt/meter which equates to 115w. I've used a 150w driver. The lights where checked before and...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi all. I just wanted to see if anyone has had issues with Fans on the same lighting Cct as LED strip lights. I have a job where the fan mech on...
