Discuss Leds glowing when off in the DIY Electrical Advice area at ElectriciansForums.net
stan22
I have a 3 lamp fitting in bedroom with led lamps which emit a very slight glow even when switched off.When I switch on light in adjacent bedroom they glow a bit brighter.They also glow a little if I switch on hall light.Can anyone help?Thanks.
This is not anything to worry about - just more annoying! The glowing or flashing effect is reported on this forum quite often.
It's most likely due to capacitative coupling from permanently live conductors inducing a voltage on the switched lighting circuit, which is causing the led's to glow. A solution is to reduce that 'ghost' voltage by fitting a 'snubber' device between (switched L) & (N) at each light fitting afflicted with the glow!
Example:
Example:
Thanks mate . it's been doing it for years . I'm sure I measured a small amount of volts with multimeter when I removed a lamp and this increased to 50V when I switched on the light next door.
Reply to Leds glowing when off in the DIY Electrical Advice area at ElectriciansForums.net
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
I have an original 250w glow plug in my 8yr old pellet boiler that's used to light the pellets during the start up phase on my boiler. The boiler...
Hey all :-) Hope its chill that I'm here asking questions, I just inherited this old decrepit place in NSW (Australia) and went to wash my hands...
I am mostly curious as I don't think this is a very important issue. In my bedroom I have 2 overhead recessed LED lights that are not on a...
I have 13 LED lights that glow all night. They are on two separate breakers
