• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Looking for electrician in West London (HA4) - pyro / MICC in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
M
Matt1976
Hi everyone,
I am looking for an electrician who can work with pyro cable, which seems to be a massive challenge as everyone I have spoken to so far either does not know how, or does not have the tools any more.
Is there anyone in the West London area who can help with this? I am based HA4 - Ruislip.
The job itself is relatively simple, I have a second floor flat where the electric meter was stolen. The meter box in the corridor of the flat itself, has the wires coming up into it and I need to fit a cut out switch for the electric company to put the meter onto. Unfortunately, the live wire is too short to go into a cut out switch as there is only 3 inches of cable visible.
Replacing the whole cable from ground to second floor is not practical as it is a pyro/MICC cable that comes up from the electric cupboard on the ground floor through the guts of the building and is embedded in the fabric of the block. The solution I have discussed with a couple of electricians is to move the meter box down the wall by 6-8 inches, exposing more of the wire and creating enough cable to put onto the cut out switch.
However, finding someone who can fit a pot onto pyro cable to achieve this is a big challenge as the technology has become less common.
Could you do this, or do you know someone who can? Any help is massively appreciated.
Many thanks
Matt
Hi everyone,
Many thanks
Matt
I may be able to help , but the cost might be very high for my services. I would need an inial visit to survey the problem, which I would require payment, on site any repairs would be paid for on an hourly basis £45/ hour plus any parts required, mileage will be 0.45 p per mile for ALL TRAVEL
but at least he'll know it's done right.
What size is the cable as I'd assume its a main feed so fairly substantial. I still have my Pyro tools and am based in W12 and could have a look if Dave can't make it.
Reply to Looking for electrician in West London (HA4) - pyro / MICC in the Electricians Jobs area at ElectriciansForums.net
Hello, I have Level 2, Level 3, Ecs card and shortly my 18th edition. I am experienced in domestic jobs (1st and 2nd fixes). I am looking for part...
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
I Need Work electrician mate job
Hi everyone, looking for work as an electrician mate in Brent, Barnet, north London and Central area in London. I've recently worked as a...
Hello, I am looking for an electrician who has an expertise in dealing with MICC (mineral-insulated copper-clad) cables. It is a domestic job in...
6K
An Invitation to Retired Electricians anywhere except the UK with Four Days a Month for a Niche Opportunity That Can Earn 15K a Year. There are...
