Discuss main isolator switch in the UK Electrical Forum area at ElectriciansForums.net
sprottp
Gents,
Looking at an install which will include two new circuits, one for lights and another for a ring main. There is no space on existing 16th edition board and customer does not want a new 17th edition board, there is no double pole isolator before it.I am planning on Henley blocking the supply and taking a live and neutral to a new RCD 2 way unit. What's puzzling me is... As there is a requirement to have a main switch for isolation rather than using an RCD main switch as the isolator, would I install a double pole isolator external to the rcd unit to meet regs? Already explored ideas of RCBOs with a standard main switch 2 way unit but clients costs are the issue. Thanks
If your being forced to cut corners to keep costs down then it's time to walk away imho. I must admit not being allowed to use a RCD main switch as a main switch is new news to me. I guess you never stop learning :)
Why do you want a main switch for isolation instead of using the RCD in the board
There is possibly more argument for a single isolator for both installations, albeit not necessarilly required
Nothing wrong with having an rcd as the main point of isolation in the sub-board. Which requirement requires a main switch instead of an rcd? Just curious...
RCDas main switch in your new board is fine, but fit a 100A D/P isolator before the henleys ( installation should have a single point of isolation ).
I must admit I even thought two main switches was acceptable if very clearly marked that there was more than one main switch. Obviously avoid this at all costs in the first place.
you`v got to look at it as an installation intended to be used by unskilled/uninstructed person/s not under supervision n all that lot....
so a single point of isolation makes common sense...doesn`t it...
Oh yeah, totally agree. Only place I have ever seen it was in a Secondary school on a condition report done by someone else.
We accepted clearly laballing at each main switch that another main switch needed to be switched off for total isolation in a nice tref label. I would never install anything this way to boot. I definitely wouldn't do it in a domestic property.
what a waste of words when a simple "muppet" would do
jeez. just nearly choked on my ale. was just taking a swig when i read that.
Another way to do it if you don't have any spares / only one spare in the existing board is take a supply from an MCB in the existing board to feed your new board and if necessary move a circuit from the existing board into your new board. Not always possible or practical depending on the condition of the old board and circuits.
Advantage of doing this is it all remains on the existing mainswitch and you don't have to pee about with putting henley blocks into the tails which you obviously can't isolate because nobody can break the seals (nudge nudge wink wink etc etc)
Reply to main isolator switch in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
