Hi, testing a UNI with one main supply, which in turn feeds around 10 separate building. Each building as it own Gas supply with meter, so therefore a Protective Bonding Conductor to each incoming supply. Does the size of the cable have to correspond to the incoming supply size, or to the size of the cable taken into the building. Also do all the bonds have to be taken back to your main earthing terminal , so right back to your main electrical intake point?
Hopefully ive made it sort of clear but im sure if i havnt your ask me something
