Discuss Metal consumer only option now? in the UK Electrical Forum area at ElectriciansForums.net
LeeH38
Following on from this saga: SWA questions, doubting electrician - https://www.electriciansforums.net/threads/swa-questions-doubting-electrician.180536/page-2
I had an electrician out to quote to rectify the problems yesterday after dealing with the tripping issue myself. I have now been told to install correctly and get this signed off you are no longer allowed to make new circuits to an existing plastic consumer (due to edition 18). As a result I have been told the 2 way consumer in the garage will need replacing and a new two way consumer will need to be added in my house to support the two new circuits meaning the spare ways in my existing consumer are now redundant.
Just wanted to check this was correct before paying for more work that isn’t required.
Lee
He’s trying to have your eyes out mate. As long as the installation is safe, there is no need to upgrade to a metal consumer unit although it may be recommended.
I’m a bit out of the loop now, not having done the 18th. The use of ferrous metal CU in domestic properties, was born out of A3 of the 17th.
It did not preclude the use of a plastic CU for new circuits, or additions etc.
I suspected this, I wouldn’t mind in the garage but last thing I want is another box with wires in the house as well as the existing one.
And why he’d add a 2 way metal consumer unit next to your existing plastic one is beyond me too...
I’d replace what you had with a new metal box incorporating the lot and leaving you with spare ways, if that’s whats required.
Lee
Forgive me for asking, but is a "metal consumer" a robot which owns the property?
And the "plastic consumer" is perhaps Pamela Anderson?
Reply to Metal consumer only option now? in the UK Electrical Forum area at ElectriciansForums.net
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
I’ve had a disagreement with one of the Engineers in work. So we are doing an install. Installing an Intruder Alarm. Rather than go with my...
5K
