davesparks
How did I not detail it? Did you not read it dave?
the meter box is outside and the consumer unit is to go in the garage it’s on the same wall about 1.5m away but the meter cupboard is outside on faced brickwork and the consumer is inside the garage”
I’d say that’s pretty good description Dave..
Yes I read it, you said "it's on the same wall" this implies that the CU is on the garage wall and the meter box is also on the garage wall.
If you had perhaps said that it is on the same wall but backing on to a habitable room, or just that it isn't possible to drill straight through into the garage, it would have been a lot clearer.
. Not been able to read the OP's deleted posts, but
