Discuss mk grid in the Canada area at ElectriciansForums.net
B
bahco
went into a house today to change some spots in the kitchen, anyway on the wall there was a 8gang mk grid switch system, can anybody explain to me how you would wire up such a thing for sockets under the kitchen units etc
thanks
hi mate if its the grid system i think you mean then ive always took a ring main to the grid and looped the lives and neutrals through all the double pole grid switches finishing on the return leg of the ring main (hope that makes sense!)
then you just connect which ever appliance socket outlet to each respective "load" output of the switches, if you have things like fans or other low current accesorries then they will be fused down by a fused grid switch prior to going though a seperate grid sw (depends on certain factors like if fan has pull cord switch for example)
hope this helps matey
rich
also to add to the above, if you wanted and you had space in the consumer unit you could always take seperate radial feeds for each appliance from cons unit too each respective grid switch then on to the appliace (this method is how a company in louth preffered to do it, which ever method you use you gotta think about the ammount of wire you have behind the grid, can be an arse to get it all to push back without giving poo ins res readings.
hi mate thanks for the reply
so im taking that the dp switch has a load and supply like a fuse spur, so you run a 2.5 down from the load side to a socket for a washing machine for example?
so the socket can be 1g or 2g? i can imagine all them wires would be murder to get nice and tidy
hi mate,
yeah you gotta load and supply side on em.
ive only ever ran the outlet side to a 1g outlet as i suppose theres a risk of overload going too a 2g skt. i.e potential of 26big ones down a 2.5
yeah there a total pig to 2nd fix, 12 ways are a bit easier with having a bit more room to work in. look the part tho
well when the time comes to do one at least i have a idear of what to expect.
not looking forward to the 2nd fix part now tho lol
yeah totally, just gotta take ya time with them n itll be cool, just make sure the wires get labelled up well at 1st fix stage.
i found it helpful to pre bend and bear off some brown and blue loops (mains side)(like when you take a feed to another terminal on a light sw), then you can just screw them straight into the terminals and crack on with the load sides etc.
yeah sounds like a good idear that i surpose its like anything the more you do the better you get.
i might never even do it lol
Reply to mk grid in the Canada area at ElectriciansForums.net
as title, am looking for square edge grid switches. I rewired a little bungalow and wired it for grid switches beside double sockets in kitchen...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
My little house in Spain sits in the forest and has a little wire from the electricity supplier, 20 amps max. It's a fragile link, caught up in...
