Discuss Moving socket on ring in the UK Electrical Forum area at ElectriciansForums.net
Shpark
Hi all,
Moving a socket on a ring 30cm sideways. Depending on how the cables come in, was going to through crimp the t & e, heat shrink over it and put it in some capping/oval conduit, bury in wall and then plaster over.
This sound acceptable?
Cheers
Not if the cables come down the wall in the plaster. With the socket gone, they will no longer be in a safe zone.
Leave the existing socket in place (or replace it with a 2G blanking plate) and it will be fine.
When ever a customer asks me to move a fitting, I point out that 'moving' a fitting is two jobs - removing the old and fitting the new, but adding a fitting is just one job.
I won't mention the compatibility between the crimps and the cable, and wonder whether the assembly would be accepted as MF to BS5733, as it won't feature in your solution due to the zone issue.
Unless I've misunderstood, once you move the socket some of the cables will no longer be in prescribed (AKA 'safe') zones.
Okay okay. Let’s ignore the safe zone thing because I’ll adhere to this. I’m asking if the way of jointing the ring is acceptable
Crimps and two layers of (ideally adhesive lined) quality heatshrink are potentially OK. It does rely on proper crimps and an appropriate tool though.
Not sure I would be burying solid conductors, assuming they are solid with crimp connectors again assuming you are going to use those red/blue/yellow types.
That's why I stipulated that it relied on the correct crimps and tools being used.
Reply to Moving socket on ring in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
