Discuss Moving Sockets in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys and Girls
Fairly new to the trade trying to level sockets in a finished apartment but the back boxes have been fixed using a spit gun. Do I have to remove the spits to make the sockets level. Just don't want to make a mess ??
If you've got a multitool you could attempt to cut the heads off of the nails and move the backboxes ,I've knocked them off with a decent sharp cold chisel in the past but thats a bit more brutal and may cause a bit of damage to the surrounding plaster .
Yeah there gal nails I just want to avoid making a mess as the apartment has been painted and the cabinets have been put in
[automerge]1589218787[/automerge]
I mean there spit gun nails
Hi Guys and Girls
left it too late to 2nd fix
If the boxes are so far out of level that you can't get the plates level using the adjustable lug then unfortunately it's too late, you can't move the boxes without chopping the plaster out around them.
Your only hope may be to try and 'persuade' the sockets slightly once they are fitted to bend the screws a little bit, but that will make it a sod for the next person along.
It’s these tilers... they come along with their perfectly level ceramics and show that the sockets are a wee bitty off.
who used a spit gun on the first fix anyway?
They should have checked the levels at the time
Reply to Moving Sockets in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Hi, client wants some sockets and 20a switches moved into high cupboards in kitchen and above 1200mm for tvs etc, the apartment was built in 2016...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hi I have a 1st fix domestic install on the go and need to leave a socket for other trades to use after me. There is no main bonding at the...
