Discuss Multimeter check for sound in the UK Electrical Forum area at ElectriciansForums.net
Marktee
Anyone knows just by looking at the back of the multimeter whether this multimeter is supposed to make sound when checking for continuity. I have replaced the fuse on the left of the image and also has a 9V battery. It works OK but never made a sound when checking for continuity.
Difficult to say. Most decent ones do, but some don't. They often have a 'sound' icon, ie like a wifi symbol to show it does audible continuity. I suspect if yours has never done this then it probably doesn't have this feature.
Try searching the web for a manual.
most meters have a buzzer that sounds for a resistance of up to around 30 ohms, in which case it would only bleep on the 200 ohm range, with a resistance of < 30 ohms connected.
Sometimes the audible beep is on the diode check setting though.
I’ve got a multimeter that’s supposed to make a sound… not same make as this one though.
It used to work, then stopped… it’s just a loose connection behind the dial. If I squeeze the thing, I can make it beep.
Sounds like a quality item 😀😀
works with 'er indoors also..
Reply to Multimeter check for sound in the UK Electrical Forum area at ElectriciansForums.net
The MS8268 multimeter has worked fine with no issues, but it's been in a drawer for several months. Batteries had corroded, but the contacts...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hello, i have a problem with mercedes glc 250 cdi 2016 it drained my battery once and when i tested it with multimeter i found it is not charging...
