sampenfold
Hi all,
I have a situation where I have been given one 17kW 3 phase inverter and one 3.5kW single phase inverter to install.
Usually when installing multiple inverters, I would install a dedicated DB for the inverters and have a generation meter for that DB. However I am unsure on how this will work as there is a mixture of single and 3 phase inverters.
Should I just install a 3 phase DB as normal, and supply the single phase inverter and 3 phase inverter from that DB with a one 3 phase meters for that DB?
