Discuss Nest Install in the UK Electrical Forum area at ElectriciansForums.net
so what mods have to be done? would these work with a 5 zone UFH system?
depends really, does the system use actuators or a zone valve? as long as you know how a heating system functions you should be fine with a nest setup, mind you with 5 zones its going to cost upwards of £1250. i havent used heatmiser so i cant comment on it
Reply to Nest Install in the UK Electrical Forum area at ElectriciansForums.net
I went to look at mess this morning. S plan heating system, google nest heat link in airing cupboard. Downstairs in utility room the kitchen...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
