Discuss new build parting wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1amp
Do current building regulations allow you to chop into a parting wall on a new build e.g a 47mm box for a cooker outlet ? Would it still pass building control ?
Reply to new build parting wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
I’m just finishing my L2 2365 at college in the evenings and plan to do the L3 2365 with the same college as an evening course. However I would...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
