Discuss not getting 240v in the Australia area at ElectriciansForums.net
C
chrisgb82
im a builder just finished refurbishing a house and had a call from the house owner saying hes only getting about 195 volts out of his living room sockets does anyone know why this could be?
Have you rang the spark who installed them? You could have a loose connection between the sockets. Could be a supplier problem if its throughout the installation!
seen as you only said living room i would say Loose Connection 100% probably a neutral
check incoming supply voltage to ensure DNO is upto scratch to be on safe side though
ill check its def only living room but thats what i was told over the phone, so a loose connection can def make you lose voltage ? i didnt realise this could affect voltage but thanx
so can this be tested in a way that we dont have to remove all socket fronts (theres 11 doubles in the living room alone)?
Wow, 11 in one room??? Is this a mansion??? Yes it can be tested at the midpoint and then halfed again until its found. You are looking at opening a few socket fronts though!
You could try and find the mid point of the ring using r1&r2 calcs but in all honesty I would remove all the fronts and check all the connections,don't mess about as you may find other loose connections there.It happens to everyone but I would say the testing side should have picked this up?
If you are dropping voltage,best get it sorted and tested
Low voltage and modern electronic equipment and appliances dont make good bedfellows
Could become an very expensive problem
how the hell would a customer who i am assuming has limited electrical knowledge be able to tell what voltage he is getting in the lounge....I mean i went to college for 3 years got all the bits of paper to wave round and now customers are telling us what kind of voltage they are getting...????????
Reply to not getting 240v in the Australia area at ElectriciansForums.net
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
