Discuss Old 3 phase Lucy Oxford main cut out- removing fuses in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
How do you remove these to kill the bus bar chamber
Is that a DNO service head.
Yes it is . Do you know how to safely get them fuses out as we need to disconnect all outgoing supplies from the bus bar.
If that is a DNO service head replace the cover and consult the supply company. Aside from being dangerous you should not be interfering with it.
Looks straight forward to me, but you answered Yes to Westward's question so as above, it's not for you to touch.
You'll be horrified with the procedure the DNO will go to to cut the power to that.
I would have said when you see what the DNO do, but they won't let you be in sight of it when they they're working on it.
And there's a fair old bit of bare copper hiding in there...
Status
Reply to Old 3 phase Lucy Oxford main cut out- removing fuses in the UK Electrical Forum area at ElectriciansForums.net
Just a FYI. I called out UKPN this week to request a supply head inspection before a complete upgrade of their domestic installation. It turns out...
Hi lads 5 year safety inspection the spark put the tails back and later line 2 of the 3 phase blew blowing the box off the wall and taking out the...
5K
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
