Discuss Old WLYEX fusebox in the UK Electrical Forum area at ElectriciansForums.net
Fully agree, but the question was will Wylex breakers fit without their correct bases, and unfortunately, the answer is, no, they won't.I think people are getting a bit extreme here.
All he wants to do is replace the rewireables to make the old boys life easier.
He’s not going to ok a rewire or RCBO board change at his age, this is the next best thing and leaves the situation no safer than it was before, but ALOT easier for the end user.
Get the correct bases and breakers, and happy days in my opinion.
Well technically they ought to be able to, remove the shroud/shield and it removes the 'keying' so anything should fit anywhere, thr obvious downside is you're likely to create instant C1s and not leaving the installation safer than you found it ?Fully agree, but the question was will Wylex breakers fit without their correct bases, and unfortunately, the answer is, no, they won't.
they will if you have access to aneedle file.Fully agree, but the question was will Wylex breakers fit without their correct bases, and unfortunately, the answer is, no, they won't.
My experience is they only trip when something else goes 'bang'.My main rationale for questioning this is that the breakers are likely to require more human interaction than the existing fuses.
This would be preferable to leaving the bases off altogether (which would also work, but beyond dangerous). The raised section around the base would also need to be removed to allow the breakers to be pushed fully in.they will if you have access to aneedle file.
5 words that are an Electricians best friend; This install is life expiredThe problem with minor upgrades is it tends to prolong the life of the installation
Beyond what it should be
True, but some judgment is also needed.The problem with minor upgrades is it tends to prolong the life of the installation
All the comments that have been posted are correct about changing etc and I am a qualified electrician however all I wanted to know was if the bases needed changing the rest is irrelevant.An instantaneous shower needs an rcd imo
Not sure what bs7671 says on that
That's no problemAll the comments that have been posted are correct about changing etc and I am a qualified electrician however all I wanted to know was if the bases needed changing the rest is irrelevant.
That's no problem
Just saying looking at that board with the instantaneous electric shower on an MCB i wouldn't be happy
Ok well I'm not familiar with bs7671 don't work here ,so can be shot downWhy not, if it tests well?
Presumably OK when it was installed.... and probably been like that for a decade or two (or three, or more).
Reply to Old WLYEX fusebox in the UK Electrical Forum area at ElectriciansForums.net
