Discuss Oven fan for BT2760SS range Oven in the Electrical Appliances Forum area at ElectriciansForums.net
Dartlec
Has anyone had experience of replacing oven fans on Baumatic ovens? Landlord has a tenant with a BT2760SS range oven, which is one of the 900m wide big things, with gas hob and electric oven.
Earlier this year, just before lockdown, I bypassed the timer clock circuit which had failed and prevented the oven from working at all (the second I've had to do that on), but the oven fan has also packed up and I am struggling to find the right part.
There are lots of baumatic oven fans around, and they all look similar, but all have different model numbers - and the one I specifically want seems to be considered obselete on all the sites I check, though their model numbers are needlessly complicated it seems.
Are all Baumatic fans likely to be the same, as long as they have the right connectors?
This is the best picture I have of the back of it...
is the fan motor burnt out, or is it just stuck up with grease, or blades catching on the casing i.e. can it be fixed?
I checked the relevant voltage was present at the terminals at the back (it was) but didn't investigate the fan from inside the oven. I had the unit out to take it apart and bypass the timer circuit so took a picture because I thought it would be a simple unscrew and swap, like elements - until I started looking.
Given it's a tenant it might well be caked in grease - but are they usually fixable when they get to that stage? It certainly wasn't coming on when it should.
I try to avoid getting into appliance repair where I can and suggest a new oven to landlords since they usually fit cheap ones, but this one is a huge double range effort that's working fine otherwise, so that's not likely to be a welcome option.
It doesn't look to be the same design as the other similar model numbered Baumatic ovens.
Maybe you could get a Universal fan to fit, looking at what's fitted in the oven I suspect it's already got a universal fitted;
Thanks - I did consider those, but wasn't sure how universal they really were - I think given the price it's probably worth trying one of those.
I've no idea if a previous one was fitted - the cooker is about 15 years old I think so it's possible.
It's just that the one fitted looks very similar to the Universal and nothing like the other Baumatic ones.
Baumatic do seem to use a different model fan for each oven so it may be the design of the the fan blade is customised for each oven.
Or cynical me might think they want to ensure you have to buy a specific replacement from them :confused: (which I wouldn't mind if they actually had one available - it's only 15 years old, not 50....)
This one was the closest looking one I found that was Baumatic I think, but couldn't verify it was the right one - and at £70 didn't want to take a chance.
Are the sizes of the mountings standard enough on most ovens? I think I'll risk one of the universal ones for now and can always keep it as spare for possible future work...
Reply to Oven fan for BT2760SS range Oven in the Electrical Appliances Forum area at ElectriciansForums.net
Hi All, Thank you for your previous advice - it resulted in us replacing our precious Smeg range with a Hotpoint; however we now have a new issue...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all, I've recently had an oven installed by AO and afterwards I noticed in the installation instructions that the electrical connection needed...
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
