A
aidan
Hi,
I'm a builder fitting a new kitchen for myself and need a little advise please.
I am putting in all the back boxes and cables in the wall to save a little money but unsure on the cooker side of things.
I have put 6mm T&E cable to cooker switch above worktops (which will come directly from the consumer unit), then 6mm T&E cable coming out below worktops.
The plan was to take the 6mm T&E cable which is below the worktop to a double socket, in which the single electric oven and 5 ring gas hob will plug into. This double socket will be accessible via a cut out in the back of cupboard next to oven.
Hope this makes sense, and if it does, will this meet building regs?
