Discuss Ovens in plinths in the Electrical Appliances Forum area at ElectriciansForums.net
Dave Appleby
Hi.
Hopefully an easy one.
Is there a simple way of removing a dead oven from a fitted plinth unit?
Has an induction hob in the worktop above.
Howdens carcasses and Lamona oven if it makes any difference.
Dave
TL;DR
Oven. Plinth. Removal. No crowbar allowed!
2-4 screws behind oven door in the sides of the oven itself when open and slide it out unless I’m missing something......
open oven door. if an electricuan has fitted it, there will probably 4 pozi screws securing it in place. if it's been fitted by a kitchen fitter, there might be 2. if a plumber has done it. it will be stuck in with mastic. if a builder has done it it will have 4" nails fired in fron a nail gun.
And you missed a perfectly good opportunity to comment on plasterers!
If it's a built under double oven you would need to remove the plinth as well to get it out, along the same lines as an integrated dishwasher or washing machine it goes all the way to the floor.
not if a plasterer has been around. there will be 4" of his muck on the floor.
[automerge]1592430431[/automerge]
see my last post. this one now it's merged.
Kev and his like use plasterboard screws for everything! The black finish fits in with the oven surround. 2 or 4 screws will be seen when you open the oven door.
kitchen fitters and screws??? yous avin a laff. kevin would not even know which hammer to use for a certain screw size.
OK..
So..
Forensic diagnosis please :D
Three screws.
2 different size Pozi and a domed slotted.
Whoever could it be? Nothing quite fits Telectrix's well thought out exemplar!
And.. What the hell... It's Friday!
Have fun all
Let's be careful out there!
Dave
Reply to Ovens in plinths in the Electrical Appliances Forum area at ElectriciansForums.net
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi all, I've recently had an oven installed by AO and afterwards I noticed in the installation instructions that the electrical connection needed...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
