Still think some guys who do EICRs have got traffic warden syndrome where the put their scheme uniform on ie a badge on a polo shirt and the power surges through their bodies. As for the Elesca man do what I do ask him to put it in writing a bit like when I advised a customer to request that BG put in writing that they no longer held spares for his boiler that was 2 years ago and he is still waiting
I've always been a bit unsure about this whole EICR thing myself. I've always been aware that it only needs to conform to the regs at the time of install but when I spoke to the elecsa man he recommended I put socket outlets without RCD as a code 1. Now, im not saying this is correct because this logic on, say a 30 year old install, would be conforming to niether the regs at time of install or the current regs (in that hes only requiring RCD on sockets and not all flushed cables) but to the 16th edition.
With regards to the OP....(ive not read whole thread so sorry if im repeating somebody else)
What you say is correct, its not required by law but it protects the landlord if the poo hits the fan. Yes you still have to pay the guy if the result is a fail, no you dont have to use him to do the remedial work.
If the house burns down, all the kids die and you end up getting investigated...if you have an EICR saying its a fail and listing the non conformities and then an installation cert from another contactor describing the rectification of said non conformities.....well...I'd say you're pretty well covered.
If you do periodics then you will be issuing a lot of danger notices if that's the case. I very much doubt the Tech team at Elecsa would give that sort of advice !
Sockets that could supply equipment out side should be a C2 not C1
depends on when they were installed....
- - - Updated - - -
look, if its a 16th ed...then sockets to be used outdoors blah blah blah....
if earlier then whats a 2 all about?
- - - Updated - - -
I've had this conversation loads of times on this forum, not gonna argue with you but BPG4 is crystal clear it should be a C2
you can offer to fit an RCD socket outlet for em....for using outdoor equipment...
theres RCD extention leads n all....
so how the hell can you just glibly award it a 2?
If you fitted a RCD socket outlet it would be ok then wouldn't it
its OK anyway....you could recommend that an RCD outlet be fitted....
look, theres all this about `well you cant have this` & `thats a fail that there is`...all a load of nonsense....
Hi Guys,
Appreciate the comments, I am the engineer that carried out the EICR on this property. My doubts were raised over the the BS 4293 having overload protection, if the device did not have overload protection I would have no alternative but to give a code 1. BS 4293 were replaced with the BS EN 61008 standard and listed as an RCCB. Rather than just failing the board on these grounds I felt I should research it first. After researching it on the internet I found much conflicting detail due to the age of the devices. I have attempted to locate federal electric technical help but to no joy. I contacted the NICEIC technical helpline however they could not give details of specific units and I was to refer to the manufacture.This article by the IET states that a RCCB has no integral overload protection http://electrical.----------/wiring-matters/15/insp-test-rcd.cfm . If anyone has any literature or information relating to this it would be much appreciated. I also understand the comments of the costing I quoted for changing the consumer unit, that is my choice given the extent of works already carried out and the simplicity of the install, given I already have the dead test values typed up on Amtech it is only a couple of hrs local work and screw fix offer dual RCD consumer units for £58.99.
Many Thanks
Hi Guys,
Appreciate the comments, I am the engineer that carried out the EICR on this property. My doubts were raised over the the BS 4293 having overload protection, if the breakers did not have overload protection I would have no alternative but to give a code 1. BS 4293 were replaced with the BS EN 61008 standard and listed as an RCCB. Rather than just failing the board on these grounds I felt I should research it first. After researching it on the internet I found much conflicting detail due to the age of the devices. I have attempted to locate federal electric technical help but to no joy. I contacted the NICEIC technical helpline however they could not give details of specific units and I was to refer to the manufacture.This article by the IET states that a RCCB has no integral overload protection http://electrical.----------/wiring-matters/15/insp-test-rcd.cfm . If anyone has any literature or information relating to this it would be much appreciated. I also understand the comments of the costing I quoted for changing the consumer unit, that is my choice given the extent of works already carried out and the simplicity of the install, given I already have the dead test values typed up on Amtech it is only a couple of hrs local work and screw fix offer dual RCD consumer units for £58.99.
Many Thanks
rite...i think i`v seen enough of this crud...
go back to college will you.....
You'll have to excuse the terminology, I did try to edit prior to anyone seeing that, clearly not fast enough. I really would appreciate some serious advice.
do these devices have an amperage rating on them, e.g. 15A, 30A etc.? if so, they're RCBOs and have O/L and S/C protection.
no probs mate...
i talks tough but i kicks tougher...:grinningelf:
