Discuss Photocell with manual override in the Australia area at ElectriciansForums.net
E
elementps
Hello,
Have been asked to fit some garden LED light fittings, supply will be coming from fused spur, total load less than 1A. The customer wants a photocell switch fitted but also ability to override and manually switch on/off when desired.
Anyone dealt with this before, would you have any wiring diagrams, descriptions?
Many Thanks
i would wire the photocell normally then wire a switch across the Lin and Lout of the photocell. or use 3core/E from spur, 3rd core to supply L to Lout on photocell via switch.
Don't some photocells have an override function built in? If you cycle the switch line on and off within five seconds they switch on permanently.
Use a three position switch, one line to photocell, one to lights and third empty. So you have the option of the p/c operating the lights, a manual on and an off.
Thats the way I've always done it, works a treat. Sometimes people want manual on if they know they have friends coming over so leave the light on all the time.
Reply to Photocell with manual override in the Australia area at ElectriciansForums.net
I'd like to wire a six pin DPDT rocker toggle switch to turn a low voltage LED fixture on and off. The rocker toggle switch I have is an...
Hi Total novi e but have wired multiple light switches previously and survived :) I've bought a nice WiFi enabled dinner switch for a new LED...
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
