Discuss Plastic Junction Box earthing? in the UK Electrical Forum area at ElectriciansForums.net
JiSingh12
Hi guys,
Quick question, I've had some people say to earth a plastic junction box with piranhas etc. whereas some people saying there's no need, since it's plastic?
I have the 5 terminal adaptable junction box from Screwfix (image attached)
From the inside of the house I have twin & earth coming into the box, connecting to 2 runs H07RN pond flex which is then going to be run to the outdoor lights in plastic conduit and with glands.
If it's confusing I can make a diagram?
You don't earth the plastic box, and you don't use Piranha nuts, since you aren't using armoured cable. However, the CPC (ie. Earth) needs maintaining throughout the wiring system.
Made by Speslberg. Many types are available with fitted terminals but usually single-row as they are targeted at mainland Europe where single-row are more widely used.
Reply to Plastic Junction Box earthing? in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
I have been asked to rewire an antique metal standard lamp. It has been rewired previously, but not earthed..! One of the screws on the base has a...
5K
