Discuss Poultry house - upgrade to solar in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
pemaldini
Hi all
I am a poultry farmer based in Zambia. For reasons I won't bore you with now, we are being blessed with up to 9hrs/day of national grid load shedding, which we are told is only set to get worse (it may rise to 12hrs/day).
Currently my 2 rearing houses (55m x 11m) each comprise of the following electrics:
  • 10amp MCB / house
  • Digital timer switch / house
  • 2 x 4' flourescent lights (external front & back) / house
  • 36 x energy saver bulbs (Osram 18W) / house
The flourescent lights feed directly off the 10amp mcb to their respective light switches, and the timer switch also connects to the 10amp mcb which then in turn handles the switching on of the internal house energy saver bulbs.
The above is replicated in each of the 2 houses. Both houses are 20m apart. House 1 has mains connected in to a DB on the outside of the house into a 32amp mcb. This is then fed into house 1 and house 2.
Given the large area of roof space (c. 720sqm each) and the abundance of sun in this part of the world and importing of solar equipment is duty free into Zambia I am interested to hear what solutions there might be for me to utilise solar to mitigate the power outages.
Would an invertor and battery system also work, charging up the batteries when there is power, and running off the batteries when there isn't.
What are the cost implications of the 2? Also bear in mind our length of day doesn't vary much, so day light hours are pretty much from 6am - 6pm. Any lighting would be needed outside of these hours, and potentially for 12hrs in a stretch.
Lastly, would you recommend running a separate standalone fridge/freezer (380ltr) for my vaccines using similar technology?
Any ideas on pricing such a system (without installation)?
Many thanks
Paolo
Hi Paolo
Sounds like a perfect PV / Battery / Diesel / hybrid grid solution, PV will charge during day, run off grid when you need to from battery and boost battery with generator when needed. Drop me your contact details and I'll send you some info [email protected]
You won't get better advice than that which you get from whilphil - he know his stuff well, listen to what he has to say and then go on that. - He won't have an 'agenda' :)
Reply to Poultry house - upgrade to solar in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
Ok so I am an electrician but don't really do solar, my partners sister has a holiday let complex, due to her energy bills rising to £36k a year...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
V.early days, just had installed solar. No battery, also supply of some parts difficult at the moment so no App or Online monitoring. I have a...
