Hey You Guys!!!!!!
Okay as promised im Back no i didnt fry myself lol
Okay you guys, went and did it much better, My big mistake is bringing in the feed in from the side and down a narrow box section, NO NO NO i tell you!
Simply not good enough Adam is it!
So after scratching my greying hair! i cam up that for sure these elements "need more space! narturally i wanted all my oven space for cooking things! sadly i had to give up some of the much needed space to allow the elements plenty of breathing space, space where its no where near any other metals!
So i decided to make a new Base! and ineserted the elements in the middle if the sheet metal¬
I then raised the sheet metal of the orginal oven base using 2 x box sections and wired into a metal clad housing and fed it from a new hole in the back!
So far its working 100% guys
If anyone else ever does this keep in mind that you will need a good bit of depth for the elements! Looking at around 10-15cm! at least
Anyway guys thanks for all you taking the time to help me out!
and took all your comments on board!
Will i make a bigger oven? yes i sure will you guys, i sure will!
Until then this old Locker will keep em buring
Till we speak again
Adios my Amigos!
