Discuss Problem with dimmable led marker lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sc1234567
I have 4 1w LED marker lights AU-WU682/1R in the ceiling with a AU-LEDD16CC driver in the loft. In the same bathroom I have 3 of the same marker lights in the floor with a AU-LEDD16CC driver in the room below. The dimmer switch I have is SF2184BC 5-150w. Each set of marker lights are currently linked to a separate dimmer switch on this, but do not dim. They only switch on or off.
In my basic knowledge and using the theory that if the switch is 5-150w, then each switch under loaded (with 4w and 3w) and that’s why they are not dimming? And in that case, can I link the two sets at the switch to increase the load to 7w, so they are both controlled off just the one switch, but still have them running off the two separate drivers? Everything is tiled and finished so rewiring is not an option.
I’m a mere homeowner with zero electrical knowhow, but my electrician has asked me to get clarification and Aurora have not been particularly forthcoming with a definite answer.
TL;DR
Can I link 2 sets of marker lights with separate dimmable drivers to one switch
Reply to Problem with dimmable led marker lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
