Discuss Problem with newly installed light in the UK Electrical Forum area at ElectriciansForums.net
SparkyAndGeorge
Hi guys just wondered if anyone had any ideas about this problem. Installed new chandelier (with 12 SES type lamps) type light that they bought themselves in customers lounge the other day, tested afterwards, working fine. Customer calls, apparently after an hour the light goes off and stops working (every single bulb) and will not turn back on at the switch. Leave it a couple of hours and the light will turn back on but dies again after another hour. Has anybody ever encountered something like this? Is it likely to be a bad batch of lamps or a fault with the fitting itself? Any help appreciated!
What tests did you do on the circuit mate?
what type are the lamps (bulbs).LED/filament/?
Reply to Problem with newly installed light in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, newly qualified spark here I went to a job earlier today where the fan was not running on after light had been turned off. Whilst...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
