Discuss Quick quote in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I’m new to self employment and I’m not sure my pricing is accurate enough. I’ve been asked to do a small job local to me and wondered if someone could give me a rough cost.
I’ve been asked to supply;
1 x stainless lantern for front of house
2 x 30w flood lights with built in PIR (for side and rear)
I’ve got the materials for around £70.00 including wiska boxes etc.
I need to do a like for like swap on a lantern by the front door.
Like for like swap on old halogen flood on side of house (high level).
Install new 30w flood at rear of house. Permanent feed taken to light, operated solely by PIR.
Also about 6-8 sockets/switches need pinning back in the kitchen. I think the kitchen was retiled meaning existing socket pins aren’t long enough.
There will be two of us on the job so not expecting it to take much longer than 1.5 hours to be honest.
Any quotes would be much appreciated.
Cheers.
minimum charge is half a day for 2 of you, whatever your hourly/day rate is. you need
to go to wholesaler. go to job, get back home. all chargeable time.
was going to sayaround £250 +materials.
One day labour charge £500 (no such thing as half a day in my book) but this kind of job you should be down the pub by lunch time easy if on your own. If its 2 of you then £250 each.
Materials what ever they are from the wholesalers , some people add 10-35% , I personally don't add a mark up as my rate covers me for my time driving to collect gear
Occupied rewires I quote £600 per day
Reply to Quick quote in the UK Electrical Forum area at ElectriciansForums.net
Been covered before, but wondering if any amendments recently. I’ve been asked to fit detectors in a bungalow holiday cottage. Just over the...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
I’ve been asked to price up a job which includes fitting a 100watt led flood on top of a 6m pole. Thinking of using a lamp post with a...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
