Discuss Radio Link Switching (200mtrs) in the UK Electrical Forum area at ElectriciansForums.net
a1guvner
Hi all,
I have a need to transmit a switched signal over about 200mtrs, I was looking at Easy switch that TLC do and have been successful with them in the past for garden lighting projects. Has anyone used something a bit more powerful as it is going to be used to send a fault signal to a plant room so I need to ensure it is reliable. Any other ideas are welcome.............
Thanks in advance
iNels by Scolmore has a good range, and I think they also do a booster. Also look at Lightwave RF. But irrespective of what you go with, if this is to trigger something mission critical then you'll have to fully risk assess it first in case of failure, and if its anything to do with a safety system then you're probably out of luck anyway!
Can’t remember the make but I ordered it from RS, I installed a 4 channel radio switch for plant control over 500m. I’ll have a look for it later.
Its not really safety critical, just to light an indicator remotely for a pump failure.
Reply to Radio Link Switching (200mtrs) in the UK Electrical Forum area at ElectriciansForums.net
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi all, I need help/feedback. I am modifying a machine. I have added an aluminium profile frame (enclosure ) to a machine (the machine will be...
Electrical2Go - Save Time Installing Cables with Super Rod At Electrical2Go, we're constantly striving to bring you the latest and most...
