K
Knobhead
I’ve just got off the phone to my ex boss (there’s a joke if ever there was one). The company he’s now working for is installing a new plant. The panel manufacturer is suggesting all multi core control cables go in to a marshalling cubical so that each cable is made fully off. So say it’s a 27 core it goes in to a terminal rail as cores 1 to 27 then jumpers run in BetaDuct to link between the multi cores to the internal panel wiring terminal. He’s wanting to do it direct style so each incoming core goes direct to the internal wiring terminal. OK again done in BetaDuct, but the spare cores are then just coiled up in the bottom of the chamber. “It cuts down on terminals by over 50% and therefore the connections” is his argument.
Out on plant I used the same marshalling system so all JB’s would have the multi cores fully made off. He’s wanting the same direct system out there.
Knowing I’ve worked on both set ups he wanted to know what I thought of it. I know which I prefer. Sorting out a rat’s nest of spare cores isn’t one of my favourite pass times, it adds hours to doing a modification.
We’re probably talking about 600 external cores going in to the main chamber so OK cutting down on the number of terminals will be considerable with his method. Doing it my way would take 1200+.
Which do you guy’s prefer?
