Discuss RCBO trips with dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
S
swifters
Hi all, I have a Bosch sms2012gb dishwasher approximately 15 years old and it has started to trip my RCBO for the kitchen. I have pin pointed the trip to where the programmer reaches the main wash cycle as the photo shows. I can reset it a few times and then it finishes as normal. I have replaced the element and sprayed the drainage pump with wd40 as there was some slight signs of corrosion on this but no where eles. The only remaining item is perhaps the main pump? I have been using it without water softner salts as I have only just discovered that you are also meant to add these. oops. Any thoughts? Many thanks. JonIMG-20121119-00085.jpg
sounds like a trip to curry's, or maybe comet's liquidator is having a sale.
Isolate to investigate was the phrase i was taught :)
insulation test from the plugtop, disconnecting a component at a time untill you find the culprite, usually heater elements, mains filter quite common too
What is a mains filter and where abouts are they on the machine? Insulation resistance line neutral was 1.5mega ohm (to be expected I suppose as there may be bulbs, transformers etc?), line to earth >200, neutral earth >200. It seems to trip when the main pump is going at it's strongest on the main wash cycle. I discconected the earth going to the main pump but it still trips. Any thoughts?
the mains filter will be right at the end of the plugtop mains cable, looks a bit like a motor capacitor,
is the pump motor leaking? we used to get a lot of tripping when the main motor seal had gone and it leaked onto the motor, not always noticable at first.
you'll need to disconnect each component completely as there all earthed through the stainless shell too, you should have more than the 1.5mohm between line and neutral, at that point in the program that to me suggests a heater element is breaking down as its heating up and expanding, but you said you'd changed it??
Yes, brand new one. I tested it at the plug. I got a similiar result with my washing machine and that still works fine. Can't see that the pump is leaking but it is tucked away so difficult to see exactly. There is no water on the floor.
I have got it! Turns out it was a cable tie trapped in the pump, don't have a clue how it made it past the filter but it must have been overloading the motor, hopefully it will last for another 15 years. ha
Don't even know how a cable tie ended up in the dishwasher...
Good job if thats the rascal but i would'nt have thought stalling a motor that tidgy would cause an overload or earth fault.But what do i know,still using the marigolds...
Tend to agree, but he did say it didn't happen till the start of the main wash, which is when the heating element would energise, so to trip the RCBO the fault current would only need to be whatever extra was needed over and above the heater load.
Whatever - he clearly needs to cook the cable ties longer so they're a bit softer in future.
It would appear you are right, it tripped again last night. Starting to lose patience with it now. Might push it off a cliff. I guess that leaves the mains filter or there was a small ceramic like holder attached to the heating element just before the electrical connection of the element that broke. It appeared to draw heat away from the element as the old heating element had no calcium/limescale deposit past that point. Or might just give up. Can you test th mains filter to see if it's broken? Don't fancy buying another part for it and still not curing the problem.
with mains filters, the easiest way is just to snip them out of circuit. all they do is stop your machine interfering with TV reception on emmeroids and constipation st. so why bother?
could it cause to trip halfway through though? It alwasy trips at the same point? e.g. when the main wash cycle starts and the motor and element are going at there best.
I know this is no help whatsoever to the op ...... but for a few days now my tumble dryer has been tripping the rcd - until yesterday when it went up in flames ..... :32:
very unlikely. it seems to me that it's motor related. you've replaced the element. time to IR the motor, check for any water leakage. process of elimination. could always take out one of those maintenance contracts, wait a fortnight, then report the fault.
Spoken like a true Scouser !! ;)
are you sure it's not metal fatigue, lugging copper to the scrappy? :nopity:
Right, this it last chance saloon for this dishwasher. I have disconnected the main filter, am sure there are no leaks, tested the main motor continuity ok and insulation resistance all >200mega ohm. However the motor that drives the waste water pump had some unusual readings. See attached photo... (IR 1.48 mega ohms continuity 63 ohms)
Does that mean the motor is buggered?
Reply to RCBO trips with dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi. Not sure if it's the right place to ask, so won't be upset if it gets removed. Apologies if the terminology (PEN/PME/etc) is used...
7K
Hello everyone. I've bought a second hand Bosch series 6 (2 years old, minimal use). The first washing went without any fault during the cycle...
