Discuss Rccb tripping in the UK Electrical Forum area at ElectriciansForums.net
Hello,
I have a machine that is only a 3ph motor 4kw with a delta inverter . When i turn off the machine from the plug the rccb (pfim 63/4/003) trips .
What is the problem and what can i do about it. Thank you
Has this just started recently?
A 30mA RCCB might be quite low for a motor inverter drive that probably has quite a lot of filtering for EMC reasons, or it might already be dealing with leakage from other circuits. What does the data sheet for the drive say about leakage currents?
lots of inverters state in the instructions not suitable for rcd supply.
not only can they cause nuisance tripping they can also prevent the rcd from working correctly due to dc leaking back to supply.
Reply to Rccb tripping in the UK Electrical Forum area at ElectriciansForums.net
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
Hi Weird problem. I’m replacing plug sockets. I isolate the circuit for the particular sockets at the fuse board so it is safe to swap out. All...
4K
I have a 110 5kva transformer. Run it off a 30 meter exstension lead running from the house into the Work shop. The transformer works and powers...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
