Discuss RCD rating too low in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
roukel01
Went to inspect a rented property the other day.
TNC-S, Consumer unit has RCD as main switch protecting all circuits. Not too keen on the idea of one RCD (16th edition install about 10 years old), but anyway that wasn't really my concearn. The RCD was only rated at 63amps and it had the following circuits connected:
45amp cooker circuit
4 x 32amp ring circuits
4 x 6amp lighting circuits
although the RCD didn't show any signs of burning out etc, I gave it a code 2 as I think it requires uprating to at least an 80amp RCD.
Now, if I get the go ahead to change the RCD, because I am altering the board slightly, am I required to bring it upto 17th edition (ie split the circuits up onto two RCD's or pop the circuits on RCBO's) or can I simply change the existing RCD for an 80amp type???
Thanks all
Not sure how you could justify a code 2 without confirming the size of the main fuse.
I agree but even more importantly, the installation has been in use for 10 years without any signs of damage and with diversity, that 63A rated device will be more than adequate. Code 4 for me.
Reply to RCD rating too low in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Did a couple of inspections on 2 x 2 bed ground floor flood damaged flats today, only 4 circuits in each, bizarrely one socket circuit and 2...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
Hey guys. I am currently studying for 2396 city and guild electrical design exam and I'm stuck on this question. Its asks to determine the...
