DoBBY
I have a garage install protected by a 30mA rcd and a 32A breaker at main DB in dwelling, I then have a new CU in garage which also has a 30mA rcd protecting sockets and lights.
When I do the RCD test I am getting bad results. When I do the 1 x the RCD in the garage CU is not tripping but the RCD at the original DB is...what the hell is going on..?
I can't put the circuit on the main switch side of the DB because there is no room so it has to stay on the RCD side....
Any ideas?
Any ideas?
