Discuss Rcd tripping times/ ramp test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
hoover
What tripping time should I expect to be acceptable when doing a ramp test on both 30ma and 100ma rcds. I mean is 70ma tripping time on a 100ma rcd too sensitive?
do you mean 70mA trip threshold? mA is not time!
70mA trip on a 100mA RCD is roughly same as 23mA on a 30. a bit low, but acceptable IMO.
No as it has passed as long as it does not trip out on half test !
Have a look at post 2 !
If you mean 70 ms well thats fine as well the quicker the better.
200 ms for BS RCD and 300 ms for ENBS RCD.
Hope that helps !
Reply to Rcd tripping times/ ramp test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Keeping this brief.....................New dwelling.....TT system with 100mA S type rcd protected supply to local board with 30mA RCD. Freelance...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
