Discuss Reactance of Wire in the Electrical Engineering Chat area at ElectriciansForums.net
Cookie
What is behind the none linear drop in conductor reactance? Is it the stranding of manufacturing variants between gauges? Or something else?
For example 8 gauge and 1 gauge wire goes up in reactance, and #6 while having a lower reactance than #8 is still higher than #10 ??
Inductive reactance (which dominates at 50Hz) is proportional to inductance. The inductance per unit length of a circuit comprising two parallel wires is proportional to arccosh(S/D) where S is the distance between centres and D the effective diameter. Constructional factors affecting these parameters include, as you mention, stranding and layup, departures from circularity and radial thickness of insulation. With real cables in real conduits, the spacing is variable so the reactance is an average anyway.
With insulation of zero thickness S=D so the inductance should follow a parabolic curve w.r.t diameter (note that gage numbers increase diameter geometrically, not arithmetically). I suspect the upwards jumps in reactance as conductor size increases correspond to steps in the insulation thickness or stranding features that locally increase S/D. They may occur in different places for cables of different voltage rating or construction.
@Lucien Nunes
So the environment the cable is in is making it's
calculated reactance vary
compared to a "neighbour" on the chart ?
..Our brains hate broken patterns..
If it helps to clarify these values are from the National Electrical Code.
Well, the environment would make a difference, yes, but the jumps in the chart relative to AWG# will be about the manufacturing differences between one size of cable and the next that affect the spacing only, or diameter and spacing in a non-proportional way. For example, shaped conductor stranding decreases the diameter (and hence spacing, but not proportionally) relative to circular stranding, without altering the CSA.
I just want to say you were correct as validated by this, reactance is less of a dominating factor with smaller wire sizes at 50/60Hz:
https://www.mikeholt.com/img/product/pdf/1038225525sample.pdf
Reply to Reactance of Wire in the Electrical Engineering Chat area at ElectriciansForums.net
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
My 1951 CA home (none of original wiring grounded) has 7 receptacles* that have a separate ground wire extended into the subfloor and connected to...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Installing a 13K peak (10K running) generator 190 feet from the panel. The portable generator is housed in a shed at the end of the property...
