Discuss Removing socket outlets in the UK Electrical Forum area at ElectriciansForums.net
Hi guys and girls,
A client is moving their kitchen into another room that currently has a few sockets in it.
The sockets are currently on a ring final circuit that covers every socket in the house.
They've asked me to add sockets for the new kitchen so I am going to run a new kitchen circuit most of which can be done in trunking as it will be behind the units going in.
My question is am I able to replace the faceplates of the old sockets not being used/covered with a blanking plate and use maintenance free wago's inside so the ring for the rest of the house is not affected? (3 sockets I think that will end up behind units)
Thanks in advance
Yes if the wagos are rated appropriately. Your proposed solution would not be Maintainence Free so would need reasonable access for future I&T. Why not just remove the S/O’s and crimp and over-sleeve?
If they not gonna be accessible I’d crimp and shrink em, trouble with wagos is they don’t class as MF if not in a wago box....not sure about the insure splice but won’t be to hard to check
If the new layout allows, I would leave the sockets in place and cut access holes in the rear of the cupboards..... or if the cables come from below, get them out of the wall and use Hager MF boxes ........
I would access the cables above these sockets in the ceiling. I would access from below as there's a pretty good chance some plastering must be going on so the small holes you make in the ceiling can be filled. I would then join the cables in a MF wago and leave in the ceiling.
I doubt the old sockets will be in an ideal place behind the new cupboards, also I doubt that the owner will want big holes cut in them simple so he can see a blanking plate in order to create the needed electrical zone. The kitchen fitter will end up just covering them up with the cabinets and then there will be live cables hidden in the walls.
Reply to Removing socket outlets in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
