Discuss replacing ceiling light in the UK Electrical Forum area at ElectriciansForums.net
I need to replace current light fitting (picture a) with terminal block in picture b. I am a complete novice at electrics and am not sure how or if I am able to fit the new light with just this terminal block. My new light wont fit over the top of the current light fitting.
if, as you say, you are a complete novice, best to pay a local sparks a call-out to do that for you. it's less than a hour's work, inclusive of testing that the circuit is safe. not more than £40 on my watch. post your location, one of us is probably close.
horse for courses I say. nearly xmas .every tom dick and harry will be on the forums doing a bit of DIY cause the wife or girlfriend bending their ear to get the jobs done being the holidays .
HO.HO.HO.
Welcome to the forum.
Unfortunately there are a few too many problems raised by your post to enable us to have confidence we would not put you at risk.
I would say that the existing light fitting should be removed entirely and you would need another terminal available.
A professional would be the best option and you could perhaps ask them for an explanation at the time, to assist you for later work.
Reply to replacing ceiling light in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
