Discuss Replacing Light Switches/Socket in the DIY Electrical Advice area at ElectriciansForums.net
Rickardo
Hi
Newbie here looking for expert advice as wanting to replace all white light switches/sockets in our flat with brushed silver
All stud walls so assume 35mm dry lined back box but for double gang socket can I fit 25mm as most state 25mm
looking at getting a couple with USB sockets. Are these practical enough. looking at 3.1amp rather than 2.1amp
What are good makes as looking an BG Nexus
Any sensible advice much appreciated
Please check that there is a cpc (earth) to each of the light switch points before going any further.
Also, I would be enclined to fit 35mm boxes to all sockets where you have enough available depth available.
Finally, although changing fittings like switches and sockets is not a notifiable job in itself, you will need the skills and equipment to ensure you have kept the integrity of the electrical safety.
Such as ring continuity and earth loop impedance
If you are changing ALL the accessories (switches, sockets, etc) in the flat, then make sure whatever range you choose, you can get all the types you need. Some ranges don't always include every type e.g. cooker isolator (without socket single/double, with socket), any coax outlets (UHF, Satellite), etc.
More than once, I've been to change all the accessories in a property, and the customer has been missing one such as the right style of cooker isolator, and they have had to take the others in the room back to change, so they can all match.
Also, if you have any double 1-gang boxes, sometimes decorative faceplates don't fit. For example, a single socket and FCU adjacent. The decorative faceplates are often a bit wider than standard white accessories.
Reply to Replacing Light Switches/Socket in the DIY Electrical Advice area at ElectriciansForums.net
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hello all, We've had a rewire and our electrican is currently away on holiday so we're unable to ask them for advice. Please can I ask for your...
I want to replace light switches in my living room. There's 2 x double switches. 1 Controls 2 separate lights in the living room. The other...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
