Discuss requirement for notifying building controll? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
disley
Ok so Im new on here and this is my first question (so please forgive me if im being stupid)
Im a qualified spark and been so for some 10 years but have always worked for a company, this company is not registered to fulfill part p as we dont do domestic work.
Im in the process of starting up in my own buisness, but not yet registered with a registration sheme provider, (Although I will be doing)
Anyway, A bulider freind of mne has asked me about wiring ome houses he is building.
Wiring, Inspecting and testing And issueing the EI Certificates is no problem but will I need to inform the local building authority myself (of the work Im doing) or will the fact that they are allready involved on the build mean they are already notified so long as all the certificates are in order?
as long as the builds have planning permission, you're OK. building control may, however, want to inspect your work... 1st fix then 2nd fix. ask the building control.
Telectrix is right in point here, although just to quibble with the specific wording. If you are not registered with a Competent Person scheme then Building Control WILL want to see stage work i.e. 1st, 2nd fix. Otherwise what will happen at the end of the build is that the Building Control Officer will come to site to undertake final sign off and one of the things he will ask for is to see the certificate stating that the job was completed by "x" electrician who is registered with "x" competent person scheme. When he is told that the spark who worked on the job wasn't registered with said scheme he may scratch his head and say "well you will need to demostrate that this electrical installation complies with Part P". I imagine the builder will then want to speak with you.....:furious3:
Reply to requirement for notifying building controll? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello, I understand that from the 15th of June testing and commissioning of vents and fans is now compulsory and that also since last year any...
4K
Hi Did a call out yesterday afternoon. Isolated a section of the downstairs ring circuit in the new extension that had a L-E fault. Bit...
Had a lovely conversation/argument with building control this morning, the scenario is this, Completed job (4 flat rewire) EIC’s sent to client as...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
