Discuss Ring circuit problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
waynelester
hi can anyone give some advice on a problem with a ring circuit.when testing end to end everything fine,when testing r1 ,r2 everything fine,problem is with insulation test,live to neutral showing dead short.also if i disconnect all links i get a continuity reading on the sockets where i should get nothing(r1,r2)
something plkugged in deffo. boiler on spur? kitchen appliances plugged in behind.
Reply to Ring circuit problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Quick question. I am new to electrical installation so please be patient. You guys are great at answers. Re Insulation Testing. Why if I test...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
