Discuss Rising main, what do you think? ? in the UK Electrical Forum area at ElectriciansForums.net
I carried out an EICR in this flat above a shop.
Incoming supply is old, single insulate tails (fabric covered stuff) possible double pole fusing, and service fuse carrier is really loose on a badly finished wall. UK power networks are saying its not their responsibility as they only take responsibility up to the incoming fuse. So who would have installed the second fuse? I thought risers were usually adopted up to the service fuse?
Supplier say its not their responsibility either, only the tails between the fuse and meter.
DNO have said to use a contractor on the Lloyds register which Ive never heard of.
Pics attached.
Are they correct?
Someone on this forum has done a lot of research and had return correspondence with DNO’s reponibilities.
It was quite interesting and informative.
Can’t remember who it was or what the thread was titled.
Are you out there?
Can you add to this thread?
[automerge]1568460176[/automerge]
This was it. I think it was vort, but his name seems to have been changed to ghost and I cannot get access to ghosts profile or any information at all.
Has vort left?
Pretty bad,no one taking responsibility,can’t really touch it can you,so leave it,you informed them so be it.
But its failing the EICR & they're not taking responsibility. If they said "yea, we think its ok" I wouldnt even be asking on here lol.
Landlord is trying to move new tenants in cant without a SAT cert.
[automerge]1568486078[/automerge]
[QUOTE="Paignton pete, post: 1573374, ]
Has vort left?
[/QUOTE]
Deleted from the forum, through his own choice or not
Reply to Rising main, what do you think? ? in the UK Electrical Forum area at ElectriciansForums.net
So this is 1st floor maisonnette with concrete floor, 16mm2 single insulated tails coming from dual cut out on ground floor, through steel...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Apologies if this is in the wrong section - appreciate it's more of an educational question. That said I have 2391 - but the classroom environment...
