Discuss Running Network cable next to power cable? in the UK Electrical Forum area at ElectriciansForums.net
JLeague
So the electrician made a hole in the outside wall to run the cable for the floodlights and in the same hole he threaded through the CAT 6 cable (shielded outdoor cable) for the POE camera.
Is this safe as I always thought you do not run network cable in the same conduit as electrical cables?
It is unlikely to cause you any issues.
And I can’t see any safety problems
Running cables in conduit is slightly different as normally they are single wires with only a primary insulation layer, what you describe would (I expect) be outdoor rated mains cable that has an overall secondary insulating sheath to protect it.
Another aspect can be interference between power & data cables, but CAT-6 style networking is quite tolerant of general noise and voltage surges as the individual data paths are twisted pairs and they usually have transformer coupling at the ends to prevent differences in ground potential causing problems.
So I would not be too worried.
Reply to Running Network cable next to power cable? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Hi All, I want to install two PoE cameras under the roof outside. But I don't know how to run a cable, drill through the wall or through the PVC...
Hi Guys Got little bit of situation, hopefully someone can advise please..... Got an EV charger going in, groundworker has only run x1 duct. Did...
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
